I am concerned about having a fuel problem on the road. It does not appear that all of the fixes such as FASS and RASP and the several pusher pumps is quite the answer as they have been failing as well. I was thinking about this and wondered why no one has come up with the idea of using gravity to get the fuel to the engine. My thought was to install a fuel tank in the bed of the truck, as many of you have all ready done, and make it the primary tank with the return line to the in bed tank and use the regular tank as a secondary tank. This would give you almost two feet of drop and there would not be so much strain on the lift pump to provide fuel to the engine. The two auxiliary tank makers use the in bed tank as an auxiliary tank only. The plumbing would not be that bad as the lines could be spliced right under the in bed tank. Most of the tank makers have as an option a gauge package so the fuel level would be known. They also have a setup to automatically fill the main tank from the auxiliary tank which could be accomplished very easily with the current setup using the existing lines to the new auxiliary tank. Anyway I do not know if this is a good idea or not but for what the different add on pumps cost and their apparent failure rate I thought this maybe another alternative. I would appreciate anyones comments.
