Question about k&n filter
Where are the "magic allignment specs" by Brett?
Clutch Problems
Would a k n filter off a 98 12v fit on a 01 24v. Thanks Barry***
2500 2001 loaded except leather all stock 354rear end 4x2
If you use the stock air box with K&N filter make sure you use sealing grease around the gasket to keep air leaks and dirt out.
Ron
1999, 3500, 6x6, slt, auto, 3. 55, Qd cab, ISB cummins, Isspro transmission temp, EGT, Boost gauges on A-piler, fuel prssure gauge, DD stage 1, DD TTPM, modified banjo bolts, K&N 0880 with prefilter, triple trailing 2001 26RKSS Tahoe 5th wheel, 1999 120hp 1800 bayliner. 20,000 lbs GCW.
