2nd Gen Non-Engine/Transmission question about my rancho shocks....
Engine/Transmission (1994 - 1998) Need part number p7100 linkage
Engine/Transmission (1994 - 1998) Need some advice.....
i put on rancho 9000 adjustable shocks about 25k mi ago at 75k mi. now i have 106k on the truck. my right font end has developed a clunk and when i lift up and down on the corners of the bumpers the right feels a lot softer/easier... . i checked the settings. they're ok. number 2 in the front. i don't "4 wheel" or go off road... ... . any suggestions ? bad shock already? thanks. scott.
It could be a bad shock, not likely but it sure could be. If that corner is soft turn the shock up to 5 and see if it does get hard then. You should excercise the valve every couple weeks anyway just so it doesn't stick.
If you turn up the shock and it doesn't respond then it is a bad shock.
