Question about RPM's
bill k.
I just took possession on my 97 5 speed. I've noticed that I can run it up to 3000 rpms. On my 3/4 ton I could only get up to about 2500 and that was it. Is the 5 speed set up different. I don;t know who the previous owner is so I can't ask him. However, the safety wire on the tamper seal over the high idle screw is gone and you can tell an allen wrench has been used on the star wheel cover. Man, I love this new truck, I can run it up to 105.
FOR SALE
Big Red" 1994 Ram 2500 Laramie SLT, 12 valve, 2WD, Auto. 140,000 miles Ranch Hand steel brush guard, Scotty Air, silencer ring put back in(wifey said so), Flowmaster muffler, chrome turn down pipe out the side, Velvet ride shackles. See Truck for Sale
<B>MY NEW TOY</b>
1997 Club Cab Dualie
12 valve 5 speed.
I have a 95' 2500 5 spd
I only get about 2300 to 2400 usable rpms.
But not for long check my sig.
Still working on your old truck.
Thanks for your time
95' 2500 standard trans. 2wd reg cab 120,000 miles bone stock but not for long I hope.
Now on order, TST #4 plate kit, 370 Diamond B injectors, Afc spring kit, Gov. spring kit.
I am Bosch and ADS Diesel Injection Certified. All you need to do to get more rpm's from the engine on the P7100 is to make an adjustment to the two governor weights or even better, replace the springs with the BD power kit. It is worth ten times its price in gold.
Chris @ AutoWurks Diesel
520 Rear Wheel H. P. and 800+ ft/lbs Torque = 15. 5 sec @ 97 mph with the rear wheels spinning in 5th gear going through the traps in the quarter mile. No slicks here, pal, no fancy auto transmission, just the truck in full street trim, 7400 lbs. of Auto Wurks Diesel/BD Performance raging, fire-breathing DIESEL POWER
B59 is absolutely correct. I had my governor adjusted by a competent pump shop which gave it the potential to rev higher. Later, I added an ATS exhaust manifold which gave it the ABILITY to rev higher. I started at 2200 rpm's and ended up at 3000 rpm's. Bear in mind the later pumps are set from the factory to run at higher rpm's than the earlier pumps.
'94 SLT 2WD, 5 Spd. , TST #6(250/635), 215 HP Injectors, Calibrated Pump, 14. 5 cm2 Turbo, ATS Exhaust Manifold, 3. 54, all Synthetics, By-Pass Filtration, EGT & Boost Gauges, Psychotty Air System, 4 " exhaust, BD Exhaust Brake, Horton Fan, Prime-Loc, Cummins Chrome Kit, Homeless Cat, Air Lifts, Rancho RS9000's, PIAA's, 255x85Rx16's and copious amounts of 12v Pride.
My 96 would turn 3000 stock. It now turns 4200 after Dave Mitchell got ahold of it.
Smoker
96 2500 4x4 nv4500 3:54 slt 3"body lift 2. 5" suspension by skyjacker 267/75/16 street tires 36/12. 5/16 swampers for mud silencer ring lost 5" pipe borla KN round style filter JRE stage 4 400hp JRE afc spring kit boost and pyro gauges 16 housing pump timed and 3000rpm limit now 4200
I believe 3600 rpm is the cut of point on stock engines. If your stock engine can spin that fast. Usually stock engines can get barely to 3000. But Governor is set at 3600.
Starting in 1996, Cummins set the engine speed a little higher to help reach the New HP rating (215). This was on 5speeds only. Very normal to see 3000. Especailly in lower gears. If you see it in 5th you have a good running motor.
jjw
ND
I can redline mine in 5th gear in a petty short amount of time. I think it's been played with but not sure because I bought it from a car lot.
