Question about WIF sensor/drain
To Idle down or not that is the question
How do I ID the 48RE ?
How does the separator work? I just changed my fuel filter at 5700 miles and when I drained it I collected about a peanut butter jar's worth of fluid. When the valve is opened does a mixture of diesel and any collected water drain out, or is it just water that has already been separated from the fuel? I expected water only, but when I opened the canister it made sense that whatever was in the cannister drained, and in fact the fluid looked to be all diesel fuel; I didn't notice any layering at all.
BTW, like others I had to add a length of 3/8"ID hose to the existing hose because the original wasn't long enough. I thought about replacing the whole thing with one length of hose that was long enough, but it has a memory and wants to roll back up.
I had noticed a slight drop in fuel efficiency and power and based on what I had read here that seemed to be the culprit. The inside of the filter was clean, but the outside was pretty dirty. I almost always get my fuel at the same Pilot truck stop, though I switch between the standard pumps and the high-pressure big-rig pumps, but I'm guessing the underground tanks are the same.
When I have changed my fuel filters(10000 miles)the only thing that comes out is diesel. So far I have not had any water. If there is water in there I think it would be the first to come out.
I'm thinking adding a better water seperator would be a good idea.
Can anyone recommend a manufacturer or model that does a good job?
Ken
