Mike Ellis
Here's another question from the wayback machine for you tool experts out there. When you're using a brace with the old style chuck that accepts the tapered square bit heads, is there a guideline for how far the shank should be dropped down into the chuck before tightening?
OK guys, I can hear you laughing out there, try not to choke yourselves :-laf :-laf :-laf --- but it's not a completely off the wall question. The way the chuck engages the taper, the bit can be inserted anywhere from "all the way in" to "just flush with the chuck opening". Inside there are usually a couple of notches that look like they should engage the top of the shank, but the engagement is kinda iffy. It is not so noticeable with the short bits, but with the long beam augers it can produce a good bit of runout so the end of the auger wobbles around in a circle.
That kind of wobble is probably OK for Moe if he's using it to drill a few holes in Curly's skull, but it seems like a more rigid grip would be useful :-laf
