question for a friend
Bigger tires on 03 DRW 4x4
Alaskan 3/4 ton conversion
A friend has a '03 Quad cab Laramie & the right rear door light won't come on when the door is opened, all other doors work. I loaned my FSM out & we're not sure where the switch is that must be hung up or rusted closed. Where is the right rear door switch located?
Thanks in advance from him.
I am not sure but it may be located inside the door and actuated off the door latch mechanism. I would also look for broken wires in the boot from the cab to the front of the door. It may be easier to check the wires first.
Matt
