Here's the story. .
I had a plug in my house that had been intermittently failing and went out. I didn't know it was failing because I have a battery-backup for my computer plugged into it and every once in a while it would "beep". It beeps sometimes when it is checking the battery, but now that I think about it I believe the power was going off and on (maybe not, my guess).
Anyway the whole circuit went dead so I replaced the breaker (it's not a gfi circuit, and it's a standard 20 amp GE breaker).
Now that the breaker is replaced, part of the circuit works, but part doesn't. I'm thinking possibly a plug has gone bad but I'm not quite sure this ever happens... does it?
Also, is there anything relating to why a plug would go bad and a breaker? (can a bad plug put a load on a braker that makes it go bad?).
ps. . The bad breaker was not tripped when I checked it (I set it back and forth a bunch with no use, but initially when I checked it it wasn't tripped).
