I'm building my own twins and I'm trying to figure out the best way to supply oil to the turbos. I have 3 different ideas:
1. Oil line into top turbo and then the drain from that turbo goes into the inlet of
bottom turbo. Then drain from the bottom turbo goes into stock location of
the engine block.
2. A Y coming off of the filter supplying oil lines to both inlets of the turbos and
two drain lines that Y back together and enter the engine block into the
stock location.
3. A Y like #2 for the inlets and then running seperate drains. One to the stock
location and pull a freeze plug for the other.
Number 1 would be the easiest for sure, but I need to know which one is the best and why.
Thanks
the engine block.
stock location.
Thanks
