Question for Joe D. Or Piers H. about timing.
LOW IDLER
Wheel Load Rating
I just received my miller timing kit and am about to set the timing to 16 deg. I have a copy of the Diesel Engine Timing page from Dave Fritz' web page. It states 6. 2mm plunger lift at 15 deg. Can I extrapolate the numbers to give 6. 4mm lift at 16 deg, or am I off base with my thinking?
Don
96 2500 4x4 5spd 3. 54 grs,#10 TST plate,AFC spring kit,16 cm turbo,CUSTOM 4" exhaust, (turbo to tail),K&N RE-0880 filter,TST guages,370HP injectors,3800 rpm governor spring kit, Mcleod dual disc clutch(street),305/70r16 Goodyear Wrangler MT tires
There's a kit that I can buy to set my own timing?
Where did you get it and how much?
Can you e-mail me.
Thanks
95' 2500 standard trans. 2wd reg cab 120,000 miles bone stock but not for long I hope.
In my possession waiting to be installed, TST #4 plate kit, 370 Diamond B injectors, Afc spring kit, Gov. spring kit. :):):)
Now here: TST's fuel pressure adapter and 2 guage pillar mount:)
On order: SPA EGT/Boost guage
Still working with Houston muffler shop on the exhuast.
Big_DQ
Could you also e-mail me on where you got it and how much.
Thanks
Brian Cobb
97 2500 CC 4x4 5 speed,egt & boost gauges, #5 tst,370hp injectors,4" exhaust,16cm turbo,Governor spring kit
afc kit,RE-0880, ceramic brass clutch,prozap
Don, according to my Bosch book CPL #'s 2023 & 2175 1996 215hp motors should be set at 5. 6mm lift for 16 degrees advance. The old 160hp auto's had a higher lift for less advance 6. 2mm = 15 degrees & that was only certain ones. for example CPL # 1968 another 160hp model is 4. 7mm = 15 degrees. Call or e-mail me if you have any questions.
Piers
If you want to try a timing light I just bought one should be here in a few days you could stop by and try it.
Sean
87 F350 dually crew cab 4x4 89 5. 9bta 5spd np205 3. 55LS 99 dana 60 front 370 pistons/injectors, BD 4" remote exhaust brake, cyberdye temp/pres gauges dual isspro egt, isspro temp monitor, kn 0880, horton fan, water after cooler, cliped hx40 16, amsoil bypass filter, remote racore fuel filter, holley 110gph fuel pump, 4" exhaust, 280 gallon in bed main fuel tank, 4 cameras fed to a vcr, built in 500mghz computer(gps tv mp3s), dynoed 317hp hit the 992 cut off on tourqe
Does anyone have the lift (mm) for 15. 0 degrees and 15. 5 degrees?
Fritz's site only goes up to 14. 5 and this thread only has 16.
Not sure if I want to go to 16 but sure want to be higher then 14. 5.
What do the experts recommend?
jjw
I got my kit from snap-on, it ran about 200 bucks.
Big DQ: If i would of known that you was need ing a timming kit, i could of let you borrow mine. I belive warrington is fairly close to the town of Linn? I have been going to school down there. I'm going to set my timming up today.
by chance you want to send your miller back i will meet you somewhere next week and let you use my kit to save some money?
Just a thought
if you are interested e-mail me or something
Adam
"POWERSTROKE THIS"
Adam Harman
95 auto red and white #6 tst , eagle alluminum wheels. Stright pipe, Goerend Converter, ramsey 8000# rear mount winch. Still BOMBING
Adam thanks for the offer on the Kit, but as much playing as I do with my truck, my kit is a valuable tool to have in the box.
Don
