Hammer
I have rebuilt a not too old P4 1. 9g system which is using Windows XP Home. It has 2 hard drives,the main is a Western Digital 120g and the storage is a Western Digital 200g. It has a MSI MX4000 video card and has 2 1g ram sticks installed.
The problem I am having with it has me lost and unsure what to look for. When you boot the system it will run through its tests and boot sequence and the Ram check then load. The problem is when it goes through this it does not recognize all the RAM and comes up short with it and slows the system greatly. HOWEVER,you restart the system and ALL of the RAM runs and when you check after it all loads it shows all of it in perfect working order.
I have went through the BIOS and made sure the RAM is set to automatic selection for clock speed and when your in the bios it shows all of the RAM also. Leave that area,boot the system and it will only show a partial RAM available. I am lost,but,with these things it doesn't take much and any help is appreciated. The system is the one my Daughter uses when she is here so I can keep her off of mine. I am at a loss and all I did was add more RAM(went from 256mb to 2g of DDR)... ... ... . Andy
