Originally posted by dmurdock
I have a small generator which will start and run the a/c in my travel traielr with no problem. I'm guessing it starts fine due to capacitors, however, I would like to verify that my a/c is getting enough voltage and is not being "browned" out while it is running. Is there some kind of guage I can plug into an electrical socket in the trailer which will give me this info? I have a real fancy multimeter with about a million different settings, would this work? (hehehe, i've just used it for continuity testing so far... )
In a sentence, yes, you can use your multimeter to check the voltage. Set the meter to A/C Volts. If it is not auto-ranging, set the range to at least 150 Volts. Turn on the generator and check the voltage at an outlet nearest (or on) the genset; it should be around 110-120 VAC. Then check the voltage at pseudo-random outlets in the trailer; the readings should all be within a couple volts of each other.
Now start turning on appliances and measure the voltage. At some point as you are turning on appliances, you may see the voltage starting to drop. As long as the voltage does not drop below the minimum required voltage of any appliance, you should be OK.
There is one caveat. Remember that air conditioners, refrigerators and other motors can draw a significant amount of current when starting up. If you are already drawing bear the max current capacity of the genset, this start-up draw could well drop the voltage below the minimum; this is a condition you should try to avoid as much as possible. (To be more specific, an occasional short drop in voltage shouldn't hurt anything; repeated often, you could be headed toward trouble.
A short definition of the limitation of a genset would be that it is designe dto produce only so many amperes of current. Once you try to draw *more* than that, the voltage will drop more than is desired.
Go through your TT and find the allowable voltage range of all the appliances. THen you will know how low you can let the voltage sag befire shutting stuff off.
I helped my brother wired in a 10KW Generac for his house in MI. When we tested it, we found we could easily run the range and oven, but trying to run the whole house as though it were connected to the AC mains would result in the voltage dropping to 104 or less. We didn't have a scope handy, so we didn't measure the frequency output.
Finally, in response to Skydiver, Watts (power) is Volts*Amperes (P = I * V).
Fest3er
