Question for the techs on the board, speedo recalibration
2010 Ram 3500 Dually- ABS Light & Service 4 Wheel drive ligh on.
New Guy; Quick Question regarding Temps
Bug Out
Is it a involved process to re-cal the speedo's on the 2013's ? I was going to have the blinkers on the mirrors turned on to as the truck did not come with tow mirrors but had both plugs in place.
If a tech is already plugged into the ECM, is it a whole new process to do the blinkers or would it just be a small set up?
Thanks in advance.
Bob4x4 ,The option was available on My WItech, It was not shaded out, I did not navigate to that option, I will check again. I did change the country of origin for the Fog and high beams to work at same time. That took some effort. I spent 8hrs (alone) just on the violation options when doing the R/D on the Stryker.
The dealer has no problem adjusting the speed-o at least the dealer in Portjeff, Ny. I had mine done when I moved up to the 285's
I had the speedo recalibrated today. They are able to do 285's.(285/70-17) He did say they have a limitation in what they can do now, compared to before.
