I'm finally getting around to putting in ARP studs and I'm confused about the wording on the little flyer that they stick in the box. It says……
"Torque values are based on 75% of the fasteners yield strength. Use the manufacturers torque sequence but do not use the engine manufacturers torque specs. Torque the nuts to 96ft lbs for ARP MOLY ASSEMBLY LUBRICANT coated studs or torque to 122ft lbs if using 30wt motor oil lubricant. "
Now, I was expecting to use the ARP Moly Lube and torque these suckers to 120ft lbs as everyone on the forum in the past has instructed. Moly lube or not, leaving them at 96ft lbs would be almost like stock right?…what's the point in that. Now I'm kind of worried about snapping one of these suckers off in the block. If I use the ARP lubricant and torque to 120ft lbs, sounds like it will be beyond the studs' capability to remain intact.
Any ideas?
Any ideas?
