As Bill Stockard stated, some medium duty vehicles use the 5. 9L. Same block as ours. Just comfigured differently. And the code letters will note the different confuguration. Not all med-duty trucks use the 8. 3L. Some are, but I’ve seen the 5. 9L in a truck similar to one that had the 8. 3L. The 5. 9 in these trucks use different pumps, injectors, etc. Sort of like the HO and the SO in our trucks. A couple of different parts and the numbers change.
If you are looking for one to swap into your Dodge, I think it will bolt in, but different electronics and things might make it a challenge to get it hooked up and running. Not necessarily difficult, but you'll have to do some homework to get it done right.
Now, the 8. 3L is used quite a bit in the larger trucks. The configuration is very similar to the 5. 9, but just bigger. And about 500-600 lbs heavier. The power numbers are usually like 300 hp and 700-850 lbs tq. And they're bomb-able. I'd like to get my hands on one and put in an older Chebby Dually.
If your company is looking to buy, I’d suggest looking for one that has the 8. 3. A bit more stock torque, and the BFCU (basic fuel consumption unit) is better. It takes less fuel to make 1 horsepower than the 5. 9, and it won’t have to work as hard.
SOLER
