2nd Gen Non-Engine/Transmission Question on door locks?
2nd Gen Non-Engine/Transmission Rubber Fuel Lines
2nd Gen Non-Engine/Transmission ball joint process...
Should the doors unlock when the truck is turned off?
They automatically lock when you start moving over a certain speed, just wondering if they should unlock automatically when the key is turned off?
Thanks
If I remeber, the instructions are in the owners manual. My wifes 05 Dodge Caravan was the same way. If you don't have a amnual let me know, and I will try to find it in mine.
One locked, I think when you stop and just pull the door handle, the door will open. At least that is what mine does. Does yours not work this way :confused:
Yes, but I often find myself needing to open the passenger door after I've hopped out (with the keys still in the ignition). So I have to run back around and hit the unlock button. It's happened often enough, that I'm annoyed with the auto lock feature.
I'll have to look in the manual and see what I find. Thanks!
Automatic Door Locks at 15mph (on/off)
1. close all doors
2. place key in ignition and cycle from off to on postition 4 times leaving it in the ON postition (do not start)
3. Press the drivers side door lock to LOCK to lock the doors within 30 seconds.
4. You'll hear a single confirmation chime when programming is complete.
5. repeat to toggle this feature.
Remote Keyless unlock all doors on first press:
1. Same as 1 & 2 above.
2. Press drivers door lock switch to UNLOCK the doors then to LOCK within 30 seconds.
3. You'll hear a single confirmation chime when programming is completed.
Horn Chirp ON/OFF:
2. Press and hold the UNLOCK button on the REMOTE for 4-10 seconds.
3. Press the LCK button on the REMOTE and then release BOTH button.
4. You'll hear a single confirmation chime whe programming is complete.
