I got a question on the Dipricol Fuel pressure gauge. First I lost the instructions to the gauge install so I came here. Should you bleed off the air from the fuel line to the isolator? Or are you supposed to leave air in the line. Also, are you to bleed off the air from the top side of the isolator that goes to the gauge? No, problem installing the antifreeze on the to of isolator but am not sure about bleeding off the fuel side. Thanks in advance
Don
Don
