I'm running the 6" lift and have noticed since the install that both links are not vertical, and, the passenger side will rub the spring from time to time. In fact, the washer above the rubber grommet has a flat spot from rubbing on occasion. I know I can rotate the spring, but, aren't these things suppose to be vertical (or close to)? Would dropping the sway bar mount (using Lorenz blocks or other) be a good idea for plumbing them or is there something else I should be concerned with? I have already removed the sway bar to see if each end were symetrical and they appeared to be. I also replaced the sway link grommets which did not improve anything (not that they would). As for sag, there might be an 1/8" difference between the driver side and passenger side (pass side being lower). Any opinions would be appreciated, thanks.
