Question regarding trailer weight calculation and design?
New TDR Chapter
3rd Gen 5ver hitch?
I'm building a 20ft 12,000lb gooseneck lowboy for my dodge. The empty weight is 3200lbs with the empty pin weight being 840lbs. This give a weight ratio of 26. 25%, which is too high. It will mean that my loaded pin weight will be 3,150 lbs. I am not sure if I calculated this right, I found the percentage empty and then applied it to max loaded weight, is that right? (If it is right, I need to drop about 1000lbs off the pin weight). I was thinking of moving the axles forward by about 2. 5-3 feet to help bring down the total trailer weight to pin weight ratio. Any thoughts good or bad about doing this?
Thanks in advance guys :)
When I built trailers I put the center of axles 1" for every foot of bed, to the rear of the center of the trailer. If you had a 20' trailer, your center of axles would be 20" rearward of the center of the bed. Make sense? That should get you in the ballpark of 10 to 12% tongue weight when setting there (and properly loaded)
Mark
Thank you so much! Exactly what I was looking for. The set of plans I bought has the rear axle 3' from the back of the trailer. Thanks again. :)
PS, when you say "center of axles" that would be the center point from between the two axles right, not the center of the front or back axel?
