Here is my proposed suggestion for the pusher pump situation.
I've been reading all about the carter pusher pumps, and the debate about the filters & high pressures when starting.
My idea is that, it seems like the pusher pump is really only needed when closer to WOT than when starting and cruising through town. I can recall a post saying that Cummins suggested that the lift pump required (of the fuel pump) required 8psi, and that any thing over was better.
Here is the actual suggestion. I believe that we all should have a fuel pressure gauge on our system, but a pusher pump is debated. Why not do a "when required" system. This can be activated in one of 3 ways.
Manual in cab toggle: If you decide you just want more fuel, fire it off.
Throttle activated: When the vehicle is at 3/4 throttle or higher, the secondary supply pump is fired off by a throttle activated micro switch which in turn supplies more fuel.
and third,
A system could be setup by a sending unit that when the system dropped to (say 6psi) the system would self support the entire fuel system. I believe that autometer would have something that would fit this operation. I don't believe it would be anything more than a low oil pressure sending unit for the auto's with a large light that warns when pressure is too low. Just hook that up to a relay and they pump would self start/shut down to meet demand.
I've also been researching all the information about elbows, banjo's as well as fuel lines. I believe I have all of my information correct. This is what I've received from Scott, a fellow TDR member:
"you will need Weber fittings and Aeroquip elbows. Both are available at either Jegs or Summit racing. These are best used with the braided SS fuel line. I used -6AN, though you can use -8AN if you desire".
At a minimum you'll need 3 Weber fittings and 3 Aeroquip elbows, a compression/-AN adapter fitting to go from the OEM hardline that exits the tank to the braided line and a suitable length of SS braided fuel line. That will take care of the inlet/outlet of the fuel filter and the inlet of the VP44 pump. Depending on if you are using the stock Carter pump, you will need 2 more Weber fittings and Aeroquip elbows for it's inlet/outlet. You will also need 4 hose ends, plus 2 more for the lift pump. The Weber fittings to are 12mmX1. 5mm. You choose the other end of the fitting, either -6AN or -8AN, depending on your fuel line size. I'm using -6AN webers and they are more than enough with a good lift pump".
Once again, I take absolutely no credit for the information presented here. This was all Scott's doing and I thank him greatly for that. If any body else has a suggestion or correction, lets hear it. I'd like to hear what has worked for others and what they would do differently. I believe that I'll be working my fuel pump here soon. I've got just over 700 miles on my truck, and I'm not looking forward to trying to resolve any fuel problems on the side of the road.
FJ40Charles has provided me with this information about the Piers Kit:
Included:
I got the kit from Piers. Included are:
1. Carter 4600 7 psi pump
2. Mounting bracket with vibration isolators
3. Mounting screws for the bracket and pump.
4. Custom wiring harness to install between factory lift pump and engine wiring harness. (no splicing necessary to hook up 2nd pump via the included relay).
5. Relay and relay wiring harness (inc. HD inline Fuse)
6. Instructions
7. 4 hose clamps
8. 3/8" npt to 3/8 brass fittings which connects to pump
9. 3/8" fuel line hose.
In closing, I'm going to attach a numerous amount of links from the TDR site that I believe would be of interest of other folks researching this same subject. If I post a direct link or picture that an individual would like to have removed of theirs, please let me know and I'll promptly remove it from this post. As I come in contact with more information, I'll promptly post part numbers and updates.
Thanks in advance,
Corey
(LATER POST)
Due to trying to keep this post all inclusive, I'm going to put some of the Aeroquip & Earls part numbers for the Fuel pump upgrade. Now, please keep in mind, as of yet, these are not exactly the correct (confermed) part numbers. If anybody CAN conferm, please do so and I'll ensure only the correct part numbers are listed. Here are what I believe are most of the part numbers, or common part numbers for our system:
Earls:
Sintered Bronze Filtering Element
EAR-230106 -6AN 27. 95
EAR-230108 -8AN 33. 95
Screen Type In-Line Fuel Filter (Flows 4-5 gpm)
EAR-230206 -6AN 28. 69
EAR-230208 -8AN 34. 69
Earl's Fuel Pressure Gauge Adapters
EAR-100192 -6AN to -6AN 8. 50
EAR-100193 -6AN to 1/4" NPT 8. 99
EAR-100194 -6AN to 3/8" NPT 8. 99
EAR-100196 -8AN to -8AN 9. 95
EAR-100197 -8AN TO 1/2" NPT 9. 95
EAR-100198 -8AN TO 3/8" NPT 9. 95
Earl's Shutoff Valves (3/8" Female NPT inlet thread 2 3/4 long)
EAR-230503 -8AN bulkhead outlet thread 28. 99
Earl's 90* Swivel-Seal (90* Bent Tube)
EAR-809106 -6AN 15. 95
EAR-809108 -8AN 20. 95
Earl's 90* Auto-Fit (90* Bent Tube) (Feed tube looks smaller)
EAR-309106 -6AN 14. 50
EAR-309108 -8AN 14. 95
Aeroquip Fittings:
90* Elbow
AER-FCM4032 -6AN 14. 95
AER-FCM4033 -8AN 17. 95
AQP Racing Hose (Full Stainless Outer Braid, compatable with most fuels, coolant & Oils. Temp Range: -55* to 300* PSI Rating: 1,000)
-6 AN Hose
AER-FCA0603 3ft. 15. 95
AER-FCA0606 6ft. 27. 95
AER-FCA0610 10ft. 44. 95
AER-FCA0615 15ft. 65. 95
AER-FCA0620 20ft. 87. 98
-8AN Hose
AER-FCA0803 3ft. 17. 95
AER-FCA0806 6ft. 32. 95
AER-FCA0810 10ft. 54. 95
AER-FCA0815 15ft. 79. 95
AER-FCA0820 20ft. 105. 9
Aeroquip AN Flare Adapters
Flare Union:
AER-FCM2052 -6AN 4. 25
AER-FCM2053 -8AN 6. 25
Union Reducer:
AER-FCM2156 -6 to -4AN 4. 95
AER-FCM2160 -8 to -6AN 6. 95
AER-FCM2163 -10 to -8AN 10. 50
Locknuts:
AER-FCM2072 -6AN 5. 25 (pack of 2)
AER-FCM2003 -8AN 5. 25 ea
Part Numbers:
Carter P4601HP (15-18psi) Carter P4600HP (7psi)
Threads:
[URL=https://www.turbodieselregister.com/forums/showthread.php?s=&threadid=19767[/URL]
[URL=https://www.turbodieselregister.com/forums/showthread.php?threadid=53888&highlight=Pusher+Pumps[/URL]
[URL=https://www.turbodieselregister.com/forums/showthread.php?threadid=53629&highlight=Pusher+Pumps[/URL]
Fuel Pump Kits:
[URL=http://www.smokindiesel.com/Dodge/24_valve/fuel_system_24v.htm]smokin diesel's fuel pump kit
Piers Diesel Kit (aux. pump)
Enterprise Diesel
Pictures from misc. TDR Members:
(RADdodge's Pictures)
and third,
Included:
6. Instructions
7. 4 hose clamps
Thanks in advance,
Corey
(LATER POST)
Earls:
Aeroquip Fittings:
90* Elbow
-6 AN Hose
-8AN Hose
Flare Union:
Union Reducer:
Locknuts:
Part Numbers:
Threads:
Fuel Pump Kits:
Enterprise Diesel
