Have any of you serious Bomber tried bigger injectors than what you needed and had good results? Lawrence at DD said - "it's better for egt if you get your hp from bigger injectors than doing pump mods". First of all, is Lawrence the right person to talk to? He seemed to be to me. If a person puts in bigger injectors, would it be better to use the biggest ones and slide the plate back to the desired power? Is that a better approach for ultimate mpg and lower egt for the resulting HP? Is there any disadvantage to that(such as poor injector performance, excessive smoke etc. )instead of using smaller injectors and leaving the plate where it is? I don't want to do a clutch job yet but I could use some more power and still get by with my stock clutch! Craig
Vaughn, thanks for the tip on the DD discount!
97 3/4Ton, 2WD, 5SP, #11 Plate, AFC kit, 14 Housing, AF942M Air filter, Straight Thru Cat, 4"From Turbo, Airlift, Shortened Frame, Custom Bed, 24CKFS Sunnybrook, HEY FORDBOY POWERSTROKE THIS!
[This message has been edited by C Schomer (edited 04-13-2001). ]
