Hey guys,
I finally received my new 2500 after about 2 months of waiting
(1/3/05). When I received the truck there were only 9 miles on the clock. There are now 125 miles on the clock now and I am noticing a few things with the engine.
1. The engine sounds like it has a pinging sound - almost like when a gas engine has got some bad fuel or the heads chattering. It was much more noticeable the first day but it has subsided just a little bit but still there. You can hear it when first accelerating through each of the gears and then die down. When I really stomp down and accelerate though the pinging stops.
2. I noticed the oil pressure gauge stay in the middle of the safe zone when driving but when stopped the needle will go to the left edge of the safe zone on the gauge. When you start driving again the needle will go back to the middle of the safe zone. My friend has a Toyota Tundra that does the same thing and is normal but I don't know if this is normal for a CTD 2500.
3. The other concern I have is when I am coming to a stop and I shift into neutral out of a driving gear the tach will bob up and down between 650 rpm and 850 rpm before settling at 750 rpm. The truck does not seem to shudder, lose power, or the lights go dim when this is occurring. We have a couple of 12 valve CTD dodges at work that do not do this - when you shift into neutral the tach will go to about 750rpm and stay - will not bob up and down.
I am not sure if this is normal operation of the new 05's or if the engine just needs to get some more miles on her. I am particularly concerned about the engine ping noise - I know there are some issues with injectors not being tightened or needing to be replaced. I don't seem to notice any pinging while idling or any white smoke at start up. If anybody could shed some light on the subject it would be greatly appreciated. BTW - the truck was assembled on 12/04/04 and it has the old door weatherstrip seals on it that rub against the front corner of the door - you would think DC would put the TSB seals on to begin with instead of the bad seals!!!
Thanks,
Brandon
Thanks,
Brandon
