Hey guys,
I will be receiving my new 2005 2500 Quad cab 4x2 6-speed manual 373 gear Diesel in January 2005 (the wait is gonna kill me). This will be my first diesel truck and I have a lot of questions. I have done a lot of reading in the forums and there are still a lot of debates on certain issues.
First - I have heard that you have to buy a special tool to get the oil filter off - is this true?
Second - There is a lot of debate about oil change intervals and oil type. I will probably change every 5,000 miles. I know you aren't supposed to switch to synthectic oil until around 15k miles but what kind of dino 15w40 oil should I use until I get to 15k miles? Is Rotella good or should I go with another? Once I do switch to synthetic should I go with the Amsoil 15w40 or go with the HD marine? Also, should I go with the Fleetgaurd oil filters?
Third - I have heard that the rear pumpkin fluid is now recommended to be changed every 15,000 miles - isn't that a little too frequent? I am getting the anti-spin differential with it and I don't plan on towing that much with it. I have heard a lot of debate about using Redline and others in the differential but not sure which one to use? Also, how many quarts go in the differential and do I just need to buy a new gasket or use gasket sealer and re-use the old one?
Fourth - There was mention of draining the water out of the diesel every time you fill up - what is this about?
Fifth - How often should I change the manual transmission fluid? What type of fluid/filter should I use and how many quarts?
Sixth - I was also told I should change all of the fluids after about 1000 miles to get all the new shavings and debris out. Should I change everything at this point: oil, transmission, and differential.
Seventh - Are there any other fluid/filter/part changes I need to take care of?
Eighth - I want to get the mudflaps for paint protection but have read that the dealer flaps will rub off the paint unless you use Clear bra. What is clear bra? Is it better to go with another aftermarket brand?
Ninth - I plan to keep the truck stock but hear a lot of talk about gauges. Do I really need the gauges?
I have more questions but these are the important ones for now. I want to say that these forums are a wealth of information and am really grateful for it. Thanks for any help!
