Questions about readings on Edge CTS
Aisin ATF
Safety Recall L16 Left Tie Rod
Last week I got an Edge CTS (gauges only). I made a run from East Texas to just west of Oklahoma City carrying a 12' dia. fiberglass tank and a "Doghouse" (a Morgan Building 10'6" by 16' by 10' high) not really any weight. The questions are what should my readings be on the fuel rail pressure at WOT. The highest I saw was 20. 5, I assume that is 20,500 psi. My manifold pressure was up to 25 lbs and my transmission fluid was 170 - 180. The hottest my water temp got was around 210, at this point I haven't gotten a egt gauge and with my water temp staying as low as it is I don't believe I will. The water temp would be much higher if the head was getting hot. The question I have is I didn't seem to have any power going into the wind and when climbing a hill. The fastest I could go was 50 - 55 mph (into a 30 mph wind) with the truck floor-boarded, this was in 4th gear (direct?) I don't believe I am getting the fuel pressure I should. I do have some fuel related codes, p0148, p0087, p0487 and also p2141 which I can't find. I know that someone is going to say pressure relief valve has let go but it is capped, so that is not the problem, it has been capped for the past 75,000 miles.
Any comments?
