Specs: 2000 CTD, 4X4, AT, "mildly" chipped but no other engine mods.
I recently installed full gauges (EGT, trans temp, boost and fuel pressure) and have a few questions.
1. I installed the EGT sensor pre-turbo in the rear (from the 3 rear cylinders) part of the exhaust manifold as everything I read says that runs hotter than the front part. Does anyone know how much cooler the front half runs?
2. It's obvious from towing with gauges that I've pushed EGTs a few times before I installed them. Is 1200* the max EGT that should be hit, or is it safe to exceed it on occasion?
3. What mods can be made, and in what order, to reduce EGTs? (It has all the pulling power I need, so I'm not looking to do anything significant to boost torque/HP. With the chip that's in it I've hit 25 psi on the boost gauge a couple of times.
4. When towing up steep hills, the EGT wants to climb, which is expected. However, the engine temp (coolant) also starts to climb significantly. Is this typical?
5. Fuel pressure is about 15 psi at idle. If I get on it, it will drop; is that typical or does it indicate an early problem with the lift pump?
TIA
TIA
