This morning I drove to work (about 5 miles) and just when I was about to turn the truck off, I looked at my FP gauge and it read 3. 0-3. 5 psi... . YIKES !
So I go to start it after work and I get my regular FP reading of 12. 5-13. 5 psi, all is cool and then about 30 seconds later it drops to 3. 0-3. 5 psi... . YIKES AGAIN !
I shut the truck off and start it up again, the same thing happens, everything is fine and then 30 seconds later it drops to 3. 0-3. 5 psi.
I know I'am in the danger zone, but at what point do you really start doing damage to the VP44 ? I keep an eye on the FP gauge and this has just started happening.
Do these symptoms sound like the lift pump is toast or do you think if might be a faulty reading ? I wasn't sure if the heater relay clicking on and off when the truck is cold might cause some eratic electrical readings ? I installed a relocation kit and a new lift pump only 6 monthes and 5000 miles ago !
I left the truck at work as I don't want to cause any possible damage to the truck. I guess I don't dare... drive it home to look it over ?
Your help would be appreciated !
Thanks !
Matt
Thanks !
Matt
