Quick ATF Fluid Question(s)
Oil level question
remanufactured 5.9?
Guys,
Getting Dirty this weekend with first ATF change and forgot to ask whether its "OK" to add non-mopar brand ATF 3+ or ATF 4 with remaining "stock" fluid left in the transmission and TC?
Any favourite brand of ATF that can be found at corporate auto centers such as Pep Boys or Kragen?
tks.
Steve
1999 2500 Quad SLT, 4x4, Auto, SWB, white with Agate leather interior, all options except fog lights. Very happy with the changed 4. 10 gears to 3. 55. 285/75 tires. Towing a '96 21ft Boston Whaler Outrage with 225 hp Johnson and galv. TT. Getting ready to BOMB because the Dodge is a little doggy towing the Whaler and my big butt. Bomb run #1, Edge EZ box. In transit: Mag-Hytek Double deep pan and Rear end cover. Next???
--What did the snail yell as he was riding on top of the turtle? ... ... . YEEE HA!!!
"LIFE IS TOO SHORT FOR CHEAP BEER and/or DODGE PARTS"
I'm sticking with mopar fluid until the warranty is up(saveing reciepts) then on to amsoil syn. Engine oil will be del400 until 25000 and them mobil syn.
20yr Mopar Parts Manager,"June of 2000" 2001 quad cab,2wd,auto,Camper pkg,354 LSD rear axle,Raven Magnum 8' cap. Mag Hitech trans pan. Isspro gauges pyro,trans and boost Apillar mount. Amsoil air filter. No muff!EZ Edge!!!! N. R. A. member
Steve, ATF+3 is all the same as for compatibility, you can mix 5 brands if you want. I buy Valvoline ATF for mine.
99 2500 QC 4X4 AUTO SB 24V LARAMIE SLT 3. 5 LSD 285-75-16'S SPA Boost/EGT Everything but leather NRA Member Great Lakes TDR Member
