Originally posted by TWest
8 bolt is a universal bolt pattern,any 8 bolt will fit any 8 hub regardless of manufacturer. It is the only bolt pattern that I known that has not change in many years. The hub center is universal also.
Originally posted by SOLER
No, the centers are different.
SOLER
Originally posted by FDavid
Are the 8 lug wheels on the hemi 2500's the same wheels that are on the diesels? (bolt pattern, interchangable... )
Thanxxxxxxxx
Yes, I am running wheels off of a hemi... ... .....
The Question was on a 8 bolt 6. 5, all 8 bolt with 6. 5" bolt pattern have the same hub size. Now a 8 bolt with a 8. 5" bolt pattern will have a different size hub, the bolt pattern determines the hub size,or center bore.
www.rsracing.com
Originally posted by bighammer
Not true. (I guess you missed my post above.)
Originally posted by VStahl
not all 8 holes are the same. THe new ford super dutys use a 8 on 170mm, I believe.
