First, I am in no way shape or form associated with ATP or their president Tim Thompson, just a very satisfied customer. I purchased the valve cover and oil pan blankets for my 06 Megacab to make my ride quieter. I visited ATP factory in Irvine CA on my way to May Madness for the install. Two of his technicians did the install. In addition to the valve cover and oil pan blankets, Tim had his technicians install an exhaust manifold, turbo/down pipe heat shield. The heat shield is made out of high tech fiber sandwiched between Inconel alloy skins. Let me tell you this heat shield works! When I arrive at Pahrump Nugget’s parking lot for May Madness from Irvine, while the engine was still running, I popped the hood and touched the top of the manifold heat shield expecting to get my fingers burned. To my surprise, it was not hot. It was no hotter than the ambient air around the engine bay. This tells me that the heat from the engine is kept within the manifold, turbo and out the tailpipe and not heating up my engine bay and the delicate ECM and other electronics and wires.
Wit all these engine sound suppressions it is making a difference. Although you still could hear the Cummins making power, it is now much quieter.
Tim’s operation is top notch. His main business is industrial, marine and military. Since he owns a CTD, he designed a kit for our truck. ATP’s product is not cheap. However, you will get the best there is from a company that’s been doing engine sound suppressions for over 35 years. Give him a call and tell him that a TDR member from Sacramento sent you and he will take care of you. ATP can be reached at (800) 826-8417, Advanced Thermal Products.
