Hello all. This is my second post as I've not had my truck for very long but I've been experiencing two issues and just wondering if these are normal or if it requires a trip to the dealer.
First, when cold (below 30 degrees) the engine surges in RPM between 750-850 at idle for about 5-10 minutes. It even does this on high idle between 1000-1100 RPM. This issue even comes up with the block heater plugged in. It disappears when hot and assumes normal idle and has only sprouted up in my first winter with the truck? The only thing I can trace it to is when the manifold heaters are cycling. Is it a problem or normal, someone let me know.
Second, my trans has a tendency after being warmed up a bit and coming off of extended O. D. operation (above 50 or so) and then coming to a turn or slow down (coasting) then re-applying the throttle after the turn or off-ramp (around 15-20 MPH) to shift annoyingly into O. D. at 35 MPH! This only happens when the truck is still in 3rd gear and on moderate acceleraton (like 1750 RPM shiftpoints). It will retain O. D. bogging the engine until the 4th gear shift (which really bumps the engine RPM) at 45 then correctly goes into O. D. at normal 50-55 MPH. Again, has anyone else had this issue, is it a normal thing on these 48RE's or does it need service?
Thanks,
Thanks,
