Rack and Pinion Bolt - Socket Size?
Fuel Tank Questions
06 ac compressor
For those of you with RWD (or those who simply know!), what size socket is required to remove the two large bolts securing the rack-pin in your vehicle?
Also, what is the torque value on it?
TYiA!
For socket size, I will have to slide under the truck tomorrow and see. For torque my 2003 Chrysler shop manual says 235 lb/ft. It does not differentiate whether a 1500 or heavy duty truck, it just has one torque in the chart of torques at the end of the rack and pinion section of Chapter 19.
Edit: I just now noticed that you have a '96 model, this is the 3rd gen forum, not 2ed gen, so I cannot guarantee the accuracy of the torque specification for a '96.
Charles
Saginaw recirculating ball pump for all of us G2's. I am thinking about "going shopping" at the local salvage yard, though. Maybe grab myself an upgrade! ;)
Everything I've seen suggests metric...13, 21, 24 plus 18 and 20 for the lines. That'll be the easiest part of converting from recirc ball to rack-and-pinion?:D
Ty, sir! Yes, that'll be the easiest part. :) I'll try and grab the parts next week, but I probably won't start the project for another month or so. Have other fish in the frying pan. If I could only squeeze more hours into a day!
