I found one post close to the problem I am having but thought I would post for more suggestions. I have a 91 auto trans 4x4 and is also heating up on grades that are not that long. Pulling about 8000 pounds and by the top, if I stick it to the floor, it is getting to the last line on the temp gauge but cools quickly after I top the grade. Pyrometer says about 900, transmission gauge says 200-220, and on the floor the boost says 20 psi. I know the trany will help the engine heat but it has an extra cooler in front of the radiator, and according to the trans place is normal temp, just not to go past 260. I had a 5 speed before and I could'nt make it heat! The radiator is a cross flow, but aftermarket. It says Radiator Performance and has a picture of a cactus by the cap. Its is a 3 core like oem, but I am thinking it is getting plugged or not a quality radiator. I have never had trouble with oem radiators. I replaced the water pump, thermostat, belt, has good shroud, fan clutch comes on normal at about 3rd line on temp gauge, checked the cap, and washed the outside of the cooler and radiator. Even when I lock out overdrive and rev her up in drive where it is easily pulling the trailer it still climbs but slower. I have good power, BUT I CANT USE IT !!!!!! The engine is very sound and has been freshed up about a year ago but didnt change the promplem. Acts like a flow issue. What do ya think.
P. S. Great site, old owner but new member!
Thanks.
Thanks.
