Radiator core support conversion?
14cm housing and exhaust brake
Converting dually to single wheel
Does anyone know if a core support from a 92 or 93 will bolt in to a 90? It would make it easy to upgrade to the later grill and radiator and add an intercooler.
Terry,
I'm almost positive they are a bolt in replacement. I'm going for the sawsall alternative as I am cheap and I'm going to try the larger intercooler from a second gen. :D
core support
Terry, I just did the same conversion, sort of! I put a 93 grill in an 84. I changed grill, core support, radiator, intercooler and all. You might have to relocate the headlights a little if you don't change the grill. The 84 grill I had rubbed on the intercooler so I changed the grill and all. Good luck in finding a 91. 5 to 93 core support. They are hard to find used.
