On my latest trip it seemed the truck was running a little warmer than it should be. On a part of my drive, the water temperature gets up over 206 and, in the past, the radiator fan would come on (or speed up), the temp would cool down to 203 and the fan would shut off. This time the fan did not come on. I checked the fuse box and the manual said F01 was for the "radiator fan controller (if so equipped)". I do not have an F01. I wonder if, as part of a recent shop visit the fuse was removed for some reason and not replaced, or is my truck not "so equipped"? How can I tell if I am supposed to have F01? My build sheet only lists "Heavy Duty Engine Cooling", and "Transmission Oil Cooler".
Assuming I am not supposed to have F01, how can I find why the fan is not operating? I checked F03 and it is good. Is there a thermostatic switch somewhere I can short to see if the fan comes on?
Edit: I assumed there was an auxiliary fan I was hearing. Maybe it is just a fan clutch.
Thanks,
Al
Thanks,
Al
