Today i tried to drain the radiator. the manual says to open the petcock.
It is plastic and appears to be of the type that only requires a 1/4 turn.
i did this with no results.
Am i wrong? Does it have to be opened several turns? Could it be plugged?
Is there a tool that works on the petcock? it is next to the aircooler outlet hose clamp, which is in the way.
I'm sure that someone out there has had this problem.
