Engine/Transmission (1994 - 1998) Radiator R&R
2nd Gen Non-Engine/Transmission speedo flying away...
Engine/Transmission (1998.5 - 2002) Hard Starting...Fixed
I have a leak in my radiator along the seam where the plastic tank is glued to the core. When I pressure test it, it holds up to around 8# of pressure. Everyone I talked to says to replace it with a new one. So that's what I'll do. I'm looking for sources of aftermarket radiators, preferably all metal.
Also, while the radiator is out, I'm going to replace the thermostat. I vaguely remember somewhere here the various gaskets and part numbers involved. Does anyone know these?
Next, I'm going to replace the leaky crank seal too while the front of the engine is exposed. I might take a look at the KDP (which I finally found out what that means). Any helpful hints or comments here?
Last, does anyone know if the Horton fan clutch is still available? Did they work as advertised?
Thanks.
