Radiator surprise!
Turbo to downcomer clamp leak
How to Adjust Valves When....
I believe I just avoided a walk home. I removed my fan and
shroud for the winter and noticed a damp place around the
lower radiator hose outlet. Hoping for a bad lower hose, I
drained the coolant and removed the lower hose. When I
wiggled the lower hose to remove it, I thought I could see a
distinct circle of green at the junction of the radiator tank and
the hose outlet! I took the hose off, it looked terrific.
Then I removed the radiator and found the solder joint on the
bottom outlet to have a nearly complete fracture around its
circumference! I buffed the brass surrounding the joint with a
wire wheel in a drill until I had bright metal, found a position
to support the radiator securely, and built up a lot of solder
around the outlet to add mecanical support to the outlet. I
pressure tested it with a motorcycle tube cut and clamped to
the upper and lower outlets(it will only generate 3-5psi), resolder
ed 2 pinholes and reinstalled it. Its running dry so far after
about 400 miles.
I believe that the trucks that have the crossflow radiator like
mine with the short lower hose may be prone to fractures, leaks,
and eventually blowing the outlet out of the bottom of the right
side tank, because there is such a violent engine shake at shutdown, coupled to the lower outlet by a short and relatively
stiff hose that the lower outlet is stressed much more than most.
I may be wrong in my suspicions, but I'm sure going to pull
my radiator shroud loose at the bottom so that I can take a good
look at my lower outlet at least a couple of times a year from now
on! (I had recently noticed my surge tank losing about a pint over
the last 4 weeks, but no green puddles or other signs of coolant
loss)
Mel good info. Also good idea with the motorcycle tube for presure testing. Sounds like you would be a good guy to have around on that surviver TV show :)
DieselBuzz,
I've used a 1 1/2"(I think) openend on the left-hand fan nut, with a LARGE channel lock
pliers to hold the edge of the serpentine pulley, but that leaves
scars on the pulley and the leather pad I tried slipped, wouldn't
hold. I was afraid further scarring would damage the belt.
I have an 18" rocker-head prybar that has the end of the handle
sharpened like a center punch. Setting it about 3/16" away from
a hex edge on the nut, holding an angle to drive the nut, and
striking a pretty solid shot with a 2# hammer seems to be an
excellent way to both loosen and tighten the nut. However, this
puts quite a dent in the nut.
I wish I had a good way to hold the pulley. I believe I read a
thread about a chain wrench. The shop manual says use a
screwdriver to engage the bolt heads on the pulley( I couldn't
get anywhere that way. )
Pull the clips on the fan shroud and lift it up and back to get to
the fan easier. After you remove the fan, take the shroud out
and store it too. That will let you take a good look at the bottom
radiator outlet to make sure its not starting to leak.
With Lund winter front inserts in all year round, I don't see any
increased operating temps until ambient high temps reach 60-65
degrees F. That's a work truck weighing 8300# ocassionally pulling a 6,000# trailer. Just don't walk off and let it idle for 2 hrs.
on a hot day. At 70 degrees the operating temp on mine goes up
quicker at idle than when the vehicle is pulling a trailer down the
road.
The easiest way to hold the pulley is to fabricate a bar that is used to hold the pulley. Use a 1" by 1/8" by 24" piece of scrap steel. Drill two holes in the steel bar that correspond to the bolt pattern of the pulley. You will then need two longer bolts to attach the bar to the pulley. Then you will have to use whatever means that you can to loosen the 36mm fan nut. I went to the local hardware store and bought a shorty wrench and then used a cheater bar. You may have to reduce the thickness of the wrench to be able to slide the wrench where it needs to go.
Bruce
:) Hey Bruce, that flatbar is a good idea. I took a 1\4 punch and drove it towards the drivers side, came right off. It's a 1 7\16" open end that I got from harbor freight. Long winded sucker! I usad the barring tool to hold things as I was doing the dowell pin fix. Tim
Bruce,
Excellent solution! Sometimes a little thoughtful field expedience
is just as effective as having your SnapOn truck on speed dial, not
to mention a whole lot less expensive!
The about 1. 5 inch diameter rubber pads below my radiator are cracked and looking kinda useless. Should these be replaced with new ones? I can't see that they actually do anything.
Tools are Cool
I purchased the tools to do this recently. Both were from OTC and cost just under $100. I purchased the strap wrench and the oversized thin fan wrench. I was able to get the fan clutch off without this stuff, but I wanted it to aid in doing what Mel is doing and remove the fan in the winter, every winter. I haven't tried them out yet as the final mocdifications are not completed for my conversion.
fan removal-- what's next
A word or two to the wise. When you put that fan back on next spring, please be sure to give the fan nut a real good:mad: tightening. If you don't, when you shut the key off for the first time after reinstalling the fan the fan may unthread itself and do serious damage to the radiator:( :( . I learned the hard way on an 89 I had a few years ago. :eek: :eek:
