Engine/Transmission (1994 - 1998) Radiator was dirty.
Engine/Transmission (1994 - 1998) Fuel Heater is Toast
I pulled out the fan clutch yesterday. I also spent a 1/2 hour cleaning the crap out of the fins in the radiator. I took compresses air and blew out the crap in the fins. Used a light behind the radiator to inspect for a perfect clean. There was a lot of stuff in there. Enough to cover the floor of the garage. I then installed the new fan clutch a Hayden if wondering. There is a noticeable difference in the amount of air going through the radiator now. This fall I'm gonna have it flushed,new T stat installed and block heater installed also.
I also staightened the and cleaned the fins on the a/c radiator. The inter cooler didn't look to bad. Also cut out a screen to put in front to keep bugs out. All in all not bad for an 8 year old. :cool:
Fess up.....
Tell about those upgrades you just got.
Clutch?
Plate?
GSK?
Mine sure is doing well in the MPG department since the headgasket change, higher timing and other stuff. I think I gain a few more hp going to the #10. Clutch still holds even pulling 20K plus.
Have fun at Joshes party!
jjw
ND
