Archived Radio and interior lights quit 2001
Archived help no taillights
Archived Where to buy rebuilt engine?
Today I had my radio playing with the key in the accesory position. I turned the key to the off position and changed the light under the hood. When I got back in the truck the radio nor the overhead lights would not work. I have checked all the fuses and could not find one blown. I hate doing electrical work more than anything and it is my weak spot. Help I need my radio.
going from memory (not good)there is a fuse believe its marked ioe or iol. in the fuse panel left side of dash. should be marked on fuse cover. think it has some kind of cover over it. best I can do with out my manual. hope it helps.
Thank you
I found the fuse marked iod with the black cover over it, changed it and it works. Thank you for the help. It is a pain to get that fuse out. Why did they ever put the fuse in that thing.
