radio dash cover
Driveshaft failure
I know I'm asking for a lot, but...
I just purchased a 2005 Dodge 4x4, 6spd, diesel, with factory radio. It will only pick up one station. Could the antenna be unhooked. how do you take the plastic cover off that is part of dash. I am afraid to pry without knowing. thks.
There is an antenna connection behind the kick pannel on the right side of the cab - - - doesn't seem that is the problem. To get the radio pannel out there are two screws that you must remove at the bottom of the dash console, pop the snap out peices out to gain access. Be real careful removing the antenna from the radio - - it has a center contact that can be bent very easy. My radio didn't work except one station on FM and XM worked - - - I found it the hard way it was a ***** study the repair manual before you start disassembling the dash.
