DavidComeau
2017 3500 (work truck) AUTO 2WD reg cab. Started engine and tried to turn on radio and just got a lit blank screen . No radio. No anything on screen. Still trying a few things and continue to push on-off volume button. Headlights on...go to store.
Drove almost 15 miles then saw a little yellow LED on the middle button heat control knob was AC on!
Turned AC led off then radio came on! Wow crazy computer?
Got home from grocery store and was going to back of bed to grab groceries and had burnt rubber smell checked both sides. Same smell Checked front wheel wells/tires-nothing.
different time:
Had error codes prior to Mass. inspection and it failed... only 14K miles? transmission low voltage? Cab no communication?
Hope to get some time this spring to work on my 96 2500 cummins auto regular cab. Only 234k until the injector pump screwed up. starts runs but engine won't pull
different time:
