Radio. Working? or Not!
Air Dog 100 Install
Center Carrier Bearing?
Has anyone had the problem of after their truck was in the shop for work the radio sometimes will work when cranked, then the next time it wont. And may not work for a couple of days. Or might work for a couple then quit the next time you kill it. And start it up agian. Iam throwing codes 514,513?06,3500,FWD,4 door, 6spd,5. 9 cummins. New South Bend clutch. 132,000 miles and counting. CBONHAM BIGREDDODGE.
P0513-INVALID SKIM KEY . . . . . . . . . . . . . . . . 9-530
P0513-INVALID SKREEM KEY . . . . . . . . . . . . 9-1994
P0513-SKIM INVALID KEY ERROR . . . . . . . . 9-1368
P0514-BAT TEMPERATURE SENSOR
RATIONALITY . . . . . . . . . . . . . . . . . . . . . . 9-1370
If they are "P" codes then this is what the manual says.
With code 513, this is probable causes
INCORRECT VIN PROGRAMMED IN THE PCM
NO COMMUNICATION WITH SKIM
NO VIN PROGRAMMED IN THE PCM
IGNITION KEY​
PCM
GENERAL NETWORK ERROR
KEY NOT PROGRAMMED
INCORRECT KEY
INCORRECT VIN IN ECM ORSKIM​
LOSSS OF COMMUNICATION BETWEEN ECM AND SKIM
514 code is battery temp sensor
BATTERY TEMP SENSOR​
INTERMITTENT CONDITION
Does your truck have the factory alarm and ignition disable? The 513 code seems to do with the key and it not communicating with the truck. Are you giving the dealer a NON-Origional key to use while the truck is in the shop?
Hope this helps.
