I've been using my Smarty Touch to data log some operating parameters. Of concern is my rail pressure at idle. Truck idles fine and runs good but has a slight knock, as in timing knock sound, at idle. Its minute but present.
When I shift from park to drive the Actual Rail Pressure (red trace) appears to have large fluctuations around my Demanded Rail Pressure (blue trace). I had a spare FCA so I installed it; however, I'm still getting about the same results with regard to engine sound (knock) and actual rail pressure fluctuation.
Demanded rail pressure is about 7,500 psi in drive and the actual pressure appears to vary +/-400 psi (800 psi peak-to-peak) around the demanded value. If I calculate the average rail pressure from the red waveform its close to 7,500 psi, so yes, the average pressure is meeting the demanded but it seems odd there are such large fluctuations...
Excel plot of original FCA. This plot is with the new parts listed below except not a new FCA.
Excel plot with new FCA. This plot is with the new parts listed below.
Questions:
Notes:
Questions:
- Does anyone else w/Smarty Touch have (or could make) a data log their demanded vs. actual rail pressure at idle in Park then shifting into Drive? I would really appreciate some feedback...
- Does anyone know if the ECM has a 'learning function' with regard to the FCA control loop? If so this may improve over time???
- If this is abnormal where do I look next?
Notes:
- New FCA (Bosch)
- New rail pressure sensor (Bosch)
- New crank position sensor (Cummins)
- Smarty Program: SW#2, TQ:1, RP:0, Timing: Stock
