I have a question & hopefully the answer isn't expensive. I noticed my fuel rail pressure gauge fluctuating while driving down the road at a steady RPM. I have close to 135K on my entire fuel system, other than Airdog LP. Truck runs fine, doesn't smoke and each oil sample sent to the lab looks good. The rail pressure fluctuation seems less if Smarty is turned down or off. Usually run it on 2 added timing, raise rail pressure setting is stock. Since my truck is an early '03, it's the 250 HP model and every little bit helps fuel mileage. My fuel pressure gauge took a dump so..I've replaced both AD filters and now that winter is here, need to get my truck back on the road. Watching the RP gauge moving at a steady RPM makes me nervous.
What say you?
What say you?
