I have question for those that have an EDGE EZ with the in-cab 3 postion switch and a rail pressure gauge. Can you see the rail pressure increase when you move the switch up from level 1 to level 2 and level 3?
The reason I ask is that I just installed a Quadzilla RPG3000 rail pressure gauge which appears to be working correctly but my in cab EZ switch doesn't seem to affect the digital readout any more than the normal fluctuation while idling. I haven't been out on the open road enough here around Atlanta to test it at any higher speeds and was curious if anyone noticed the EZ's effect on the rail pressure readout.
Long story short --- a while back I accidently managed to pull the small switch assembly apart when taking my A-pillar off where the switch is mounted. I pieced it back together I thought correctly but it doesn't appear to be affecting the power level or rail pressure at all now. I just ordered a new in cab switch assembly from EDGE which should arrive in a few days.
Any comments would be appreciated.
Thanks, Bill
Thanks, Bill
