from the stock air filter mounting local there is a straight shot from air box to front of the grill. there is enough room to snake in a piece of 1. 5"(maybe larger) PVC ,cut hole inside of box, install a globe valve inline so that you can open and close at the end of the 1. 5" pipe a large collector. Should cost 15$ and take about 45min install. add a k&n to this system and you will probably lower egts by a considerable amount without having to spend $ 300 bones which i think is sky high! this system should work i will install it on my 03 when i get a chance and let you guys no. This is all in my mind right now but i will think more i am hoping to add in can adjustability. which will be easy i am going to see how it effects egt first. there is still no drop in oil filter out though which will be the key to making this ram air work. i have also though about cutting a hole in bottom of the air box and route some plumbing to the air dam and cutting holes in it to set a couple off collectors which would look similar to the chevy ss truck which has those two collectors in the air dam. this would probably work the best. but my 1st system would collect air further away from the ground which will help lower the temp of the air during the summer.
oh yea there will be a screen over the front of the collector.
