Ram Hood Ornament.
Alloy wheels
Shocks
Does anyone have one on there 94 and later truck? Who can I get one from?
95 Dodge Ram reg cab,2500, T. M. S. Cummins Diesel,5spd, MODS,torque plate forward,star wheel forward,Plugged wastegate, K/N filter,dual exhaust 5'' tips,Lost muffler,fixed cat,Lost turbo silencer, ACCESORIES,ISSPRO turbo & pyro gauges pioneer cd,Cobra Nighthawk c/b,Wilson whips. 117k. on the OD.
Big bad Dies
I just installed one on my 97. I bought the ram head from the dealer, price was $58. 00. The instructions and measurements are for a first generation truck. You have to drill 3 holes in the hood. Study the sheet metal on the bottom side and remove the hood latch for installation. There are one, two, and three layers of sheet metal in the front area of the hood. If you place the ornament correctly, only the third or most rear hole will go thru two layers of sheet metal while the two front holes will go thru a single layer. Drill the center hole from the bottom side first, then you can make final alinement adjustments and drill the other two holes from the top.
The Mopar hood ornament costs twice what Whitneys wants but the quality is more than twice.
'97 SLT 2500, 4x2 LB Club Cab, auto, 230/605 fuel plate and 215 injectors, pillar mount Isspro gauges, BD torque converter, BD valve body, BD Pressureloc, Mag-Hytec transmission pan and differential cover, 3. 54 LSD, white/driftwood, air dam, sliding rear window, towing/camper pkgs, Rhino liner, SS bed caps, stake pocket tie downs, chrome exhaust turn down, SS wheel well trim, Carr steps, Mopar mudflaps, Aerotank under seat toolbox, Cobra 75WXST CB/Firestik, J-MAC louvered aluminum headache rack and tail gate, Reese 15k fifth wheel hitch. Mopar Ram hood ornament and white dice. Kennewick, WA.
JC Whitney, I just bought one that is chrome and cost 17. 99. Do NOT order the 94 and above hood ornament, it is ugly and comes mounted on a chrome dome. You can also get gold and illuminated eyes. Easy to mount too. After drilling holes in the hood #ad
'98 ext cab 4x4. Skyjacker 4. 5" lift w/ 36" swampers. 370 injectors, pump done right, Scotty air, HX40 18. 5 housing, JRE stage III fuel plate, McLeod dual disc street clutch-"Mitchellized", ISSPRO gauges, 4" black smoke puffin'-hear me CUMMIN chrome stacks. A member of the best brotherhood around-TDR.
**Skyjacker raised**
**Cummins praised**
