GWoody said:I always plug the TST in first.
MikeS1 said:I finally got ahold of TS Perforrmance and they said that with their box it needs to be plugged in before the TST because they change all the map and fuel pressure signals, have you guy's tried to run it with he Ramifier 1st?? Mike
moolie said:hey mike u gonna go run today or what. go lambifier
MikeS1 said:I just got back from swapping the connections and putting the TST 1st on the map and it still smoked like a freight train until these twins start going; 10X what it did with the EZ on 4, so I called and talked to Chris @ TS Performance and he told me that the Ramifier needs to go 1st, so I asked him about how does the TST know when to fuel if you are changing all of those signals, he said that the fueling signal of the TST is a implied or set signal that they use, and in my opinion they use pretty well. Just FYI. Thanks for the help, I do appreciate it. Mike
MikeS1 said:What I meant to say was that Chris at TS said that the actual signal that the TST uses to fuel not the TS is a implied or set signal. Sorry I did not explain that very well I have never been a very good typer :-laf
tomeygun said:Thats kinda screwy - If the TS caps the output signal to read 21psi - And the TST fuels all ther way till 35psi... in theory you will never get the full pulse of the TST because the TS will never tell the TST higher than 21 psi.
wierd, Then again, I have no idea what the output signal is like on the TS, maybe the custom program dennis has does NOT cap PSI signal... .
Jeff_K said:That make sense unless Mike is running the TST twins program, then it doesn't matter because the TST is all in at 12psi
jglasgow said:Mike, How much boost are you making with your twin set up?
Thanks,
John
jglasgow said:Mike, I'm using the Aurora 2000 by ATS on top(I think its a B1) and a B2 on the bottom. Before I got the external wastegate adjustable in the cab, I hit 74lbs of boost. Now I have it set at 60lbs. I don't know how far you can push it running just head studs but I'm sure I'll find out.
John
