First of all, comparing 70HP EZ to a 125 HP Ramifier is like apples and toyotas. The Edge number is an "apple" and is a measured "total peak RWHP gain over stock peak RWHP". literally it is the difference between the highest HP point on the stock curve (2900 rpm) and the highest point on the enhanced curve (whereever that is)
Secondly, the Ramifiers 125 HP gain is on a 235 HP SO engine not a 305 HP HO. the 305 HP engines don't respond as well. While TS informs me that their box "makes 100 HP" on a 305 HP engine, the basis of that data continues to elude me (TS has not release a dyno graph to the public). Accepting 100 HP for sake of discussion, it is still a toyota because it is measured differently than apples are.
Third, TS measures toyotas, not apples, because Toyotas are bigger than apples. To measure a Ramifier toyota, you take the largest difference between the stock and enhanced curves, at whatever RPM that is. some call that "best gain" and is very common in the industry. especially for boxes (like the Ramifier) that bring the power in sooner (at low rpms) the difference between stock and enhanced will be a very large number.
I have attempted to convert toyotas into apples for comparison purposes. After this is accomplished, you see that the ramifier and the EZ are within 10%. considering that one is a measurement made at high altitude and the other is given out over the phone without dyno measurements behind it, Id say Ramifier is no more powerful than the EZ.
see
fueling_box_summary for an explanation in more detail.
Now then, the ramifier's strength is in its low-rpm power -- big drivability difference, seat-o-pants meter and overall smile. Thats because it makes a huge difference in torque output at 2,000 rpm. at 2900 rpm, and without dynamometer data to the contrary, we must assume that it can make no more HP than the EZ does at peak output. otherwise its pressure is elevated higher than the EZ is.
We all know and respect that the EZ's hidden jumper settings went away because of the risk associated with higher pressures. We also know with certainty that the EZ and the Ramifier are on equal footing at full output (WOT 2900 rpm). Therefore we must conclude that either of the following is true:
1. Ramifier makes no more peak HP than EZ
2. Ramifier raises pressure higher than EZ
I am of the opinion that #1 is true and that both the EZ and the Ramifier make similar (within 10%) HP at to top end, and do so with fuel pressures in the 27,000 psi region. Where Ramifier outperforms the EZ is in the low end, where its fancy boost fooling brings in the power sooner and therefore it can provide more pulling torque in the RPM region of interest for most highway pulling.
In cab adjustability is a personal thing. me I wouldn't leave home without it, simply becaues my truck does everything from city commuting, towing, to offroad. when I go offroad crawling I don't want my 02 sensitive throttle to come back as a ghost to haunt me and toss my passengers all over creation.
