A friend of mine ran out of fuel Friday night, could not get it started and called me about 10 PM.
He is a pipeline welder and his 3500 4x4 is very heavy. I towed him to my house and Sat. AM we spent about 3-4 hours getting him started.
We called the local dodge dealer and was told to loosen # 1,3,4 (as they were the easiest to get to), and 'bump' the engine over, leave the key on and the lift pump would run for 20-30 sec. until we saw bubbles or fuel coming out. Not exactly understanding the way this system worked, I was looking for fuel to come spraying out as the lift pump was running. Well, after a while, I called him back and was told that the injector pump had to be setting on the injector we had loose before fuel would come out. Finally, after only loosening one at a time, and watching with a flashlight, I could just see fuel leaking out when the engine stopped on that particular injector.
Now, after this Long post, there seems should be better way. First, Do Not Run Out Of Fuel!!
Second, is there a way to 'jump' the lift pump to run all the time while turning the engine over by hand and watching for fuel to leak out of the injectors. You should be able to watch in the firing order from one injector to the next. Would this work?
Any help would be greatly appreciated and helpful. Thanks, and sorry for the long post.
Ron
'01. 5 ETH, DEE, 2500 Silver, QC, 4x4, SB. 3. 54 LS All options except leather. Not bombed Yet. Life Member NRA & NAHC. Ron Osborne
Ron
